Dureza muelle amortiguador original 1200gs
SAVINO
29 Nov 2004
Hola, tengo un amortiguador bitubo con muelle 14 kg\mm, creo que es blando.
Me gustaría saber la dureza del muelle de serie en una gs1200 2010.
Por favor, si alguien lo sabe estaré muy agradecido pues me está costando encontrar este dato.
Saludos gracias.
He encontrado algo, parece que coincide con el OEM: 14kg/mm o 140kg/cm que es lo mismo.
"I've read here in advrider, that the stock 12GS springs are 52nm front and 140nm rear.
I just put Ohlins on my 2007 12GS and hardracing.com sent me 54nm spring in front and 140nm spring for the rear. I'm 240lbs so I understand the heavier spring up front (which is about perfect), but rear seems about right too and it is supposedly the same rating as stock. It seems the Ohlins 140 is stiffer than the oem 140?
It's all very hard to figure out, especially since my 1150GS with Ohlins, I used 56 up front and 160 rear, which were perfect."
