la st
Make Model
BMW F 800S
Year
2006
Engine
Liquid cooled, four stroke, parallel twin cylinder, DOHC, 4 valves per cylinder
Capacity
798
Bore x Stroke 82 x 75.8 mm
Compression Ratio 12.0:1
Induction
Electronic intake injection
Ignition / Starting
/ electric
Max Power
62.5 KW 85 hp @ 8000 rpm
Max Torque
80 Nm @ 5800 rpm
Transmission / Drive
6 Speed / belt
Frame Bridge-type aluminium frame
Front Suspension
43mm Telescopic forks, 140mm wheel travel.
Rear Suspension
Die-cast aluminium single sided swinging arm with rear wheal axle and eccentric adjustment, central spring stud , spring pre-loaded hydraulically adjustable to continuously variable levels by means of handwheel, rebound damping adjustable, 140mm wheel travel.
Front Brakes
2x 320mm discs 4 piston calipers
Rear Brakes
Single 265mm disc 2 piston caliper
Front Tyre
120/70 ZR17
Rear Tyre
180/55 ZR17
Dry-Weight / Wet-weight
- / 206 kg
Fuel Capacity
16 Litres
Consumption average
Braking 60 - 0 / 100 - 0
Standing ¼ Mile
Top Speed
