Matthew.J.Garcia
There is no doubt that a  vacuum is the most important machine in helping you with cleaning tasks. But here comes the tricky part: what is the best vacuum cleaner? How can you tell the differences between various types of vacuums? Which one is the most useful for your situation? We hope you will know what is a good vacuum and which one you should get after this article.
What's a good vacuum cleaner
Vacuums come in different shapes and sizes, each is designed for a particular job. So before jumping into the "top 10 vacuum cleaners" search, you should decide what kind of vacuum fits your demand the most. Here we have a quick summary of 3 main types of vacuum for you to choose from:
And these 3 types can be either:
Choosing what type of vacuum depends a lot on your demands. Do you only want a main floor cleaning vacuum or one with a lot of attachments to help you clean everywhere, one efficient in cleaning pet hair or one can fit in your car,... Of course, we all want a multipurpose vacuum, but the price won't be low to have such a brilliant machine. That's why you must decide what type of vacuum fits your demand the most. Then they'll be your best vacuums cleaners in the world.
Best rated vacuum cleaner
Now that you know different types of models, you can start with vacuum cleaner comparisons. Here we have a simple comparison that can help you decide quicker base on your circumstances.
So here are our examples to help you choose your vacuum easier. But you can be more detailed by making your own list of pros and cons. In the end you can reach to the conclusion with the highest rated vacuum on the list. If you still unsure what you should get, then we have these top best vacuum cleaner brands. Check it out and maybe your dream vacuum is right on this list.
Best rated vacuum cleaners
1. Shark Navigator Powered Lift-away NV586
This is a perfect bagless upright vacuum. Easy to move, quieter compared to other upright models, works excellent on bare floors, carpets and ace in collecting pet hair tasks.
2. Miele Complete C3 Marin
An efficient bagged cylinder vacuum with powerful suction. This makes attachments work like a miracle. It only gets a bit tricky moving around, but that's a common cylinder vacuum problem that can't compare to its benefits.
3. Shark Ion W1 WV201
A strong cordless vacuum that can take care of any kind of problem, just like a professional upright vacuum. Its only downside is a small dustbin. But what can you expect more of a space-saving like this model? If you’re in for convenient, this is the vacuum you’ve been looking for.
4. Tineco Pure One S11
A cordless vacuum that looks like an upright vacuum but more convenient. Its most outstanding feature is the clogging alert. You can also change suction power to your liking and the dust sensor helps a lot in choosing the right amount of strength.
5. Kenmore Elite Pet Friendly
A bagged upright vacuum for pet lovers. Its powerful suction makes cleaning tasks easier than ever with all the attachments included. The most important feature is its ability to clean pet hair, let owners have more time playing with their beloved pets instead of cleaning up after them.
We hope this best vacuum cleaner reviews give you some examples of a perfect vacuum for your household. But the online vacuum ratings are just for recommendation, everything is up to you, depending on your situation. Choosing the right vacuum is the very first step of achieving a carefree cleaning routine. So make your choice wisely and let the vacuum helps you clean all your worries away.
- Upright vacuum: the vacuum goes in front of you, and you push the whole machine on your cleaning route. This is the best model nowadays and usually comes with turbo brushes. Its suction power is a huge advantage in cleaning different types of areas.
- Cylinder vacuum: it has a flexible hose for cleaning and you drag the machine behind every time you change location. This is a typical and traditional model, which suits an average budget.
- Cordless vacuum: you can take this vacuum anywhere because it runs on batteries and light-weighted. This model is handheld so you don't have to push or drag, super convenient.
- Bagged vacuum: all the dust will be transferred into a disposable bag so you don't have to get your hand dirty, but it requires replacements.
- Bagless vacuum: has its own container that can be reusable, but low on capacities and may get messy when emptying.
- Upright vacuum: the best for a large area, especially carpets. If you have a problem with pet hair, this model can be a huge lifesaver. Using this vacuum gives you a comfortable upright position, and it's easier to weave between furniture. It's also more comfortable to store with a whole machine intact. However, this model can be tricky to use when it comes to stairs, small areas and under furniture. It's noisier and has a shorter cleaning distance compare to other models. It's also kind of heavy and not very affordable.
- Cylinder vacuum: this is a common model and works on more spaces, especially hard to reach areas like stairs or under furniture. With its flexible hose, you can have a larger cleaning distance compare to an upright vacuum. With a reasonable price, every family can easily buy one. And quieter when working is a bonus. But this model is not very efficient with cleaning carpets and collecting pet hair. Storing it can be a little difficult with the extended hose and if you're not careful while dragging it around, you may damage your house if it bumps into walls and furniture.
- Cordless vacuum: this model's biggest strength is convenience. You can fit it in small spaces like your car, where there is no socket to plugin. Lightweight and handheld is its best feature. But that comes with a disadvantage of low suction and non-lasting power. This may get annoyed if you have a lot of stubborn mess to clean up.
