Las grandes Trail
para mototurismo me parece el mejor sistema para llevar mucha carga, no transferir pesos,ni descomponerse y transmitir seguridad.
para correr y off prefiero las horquillas, por, ademas sus infinitas configuraciones
aqui pongo un articulo sobre el telelever EVO ... bastante bien explicado
"With the new Evo Telelever, BMW Motorrad now combines the strengths of the two previously used Telelever variants. Clamped tightly to the fork tubes — as previously in the sporty design — the upper fork construction incorporates a handlebar decoupling system that prevents any detrimental tilting movement and only transmits steering forces. The tubular handlebar is clamped in a handlebar bridge via two clamps. The connection from the handlebar bridge to the upper fork bridge is the core element of this construction: a strikingly showcased stainless steel plate — the so-called flex element. Due to its flexibility and geometric design, it is able to compensate for the tilting movement while at the same time transmitting steering forces. The actual upper fork bridge is pivotally and rotatably connected via a radial swivel bearing to a sturdy steering shaft tube, which in turn is guided in the main frame via a cylindrical roller bearing at the top and a deep groove ball bearing at the bottom. This sophisticated construction creates significantly greater rigidity, which is reflected in the noticeably increased ride stability of the new R 1300 GS. The simultaneous addition of an extra roller bearing for the ball joint in the lower fork bridge also ensures thrilling steering precision due to the lower bearing friction. The diameter of the quick-release axle, which is approximately 1.7 ounces lighter, has been increased by 0.2 inches to 1 inch, increasing the stiffness of the front wheel guide."
No dice que te permita leer mejor el terreno, sino que es más "preciso" ... NO es lo mismo. Sin duda las sensaciones para el piloto seran que tiene más control pero no se hunde en la frenada por tanto no puedes saber como esta pisando la rueda.
Y esto no es ninguna critica, al contrario ....Personalmente, me encanta que BMW siga buscando este santo grial: el telelever, el durolever, el telelever evo ... y sinceramente, no encuentro un sistema de suspensión mejor para una moto de turismo y especialmente para viajar a duo.
Por otro lado las suspensiones de horquillas también han avanzado para hacerlas menos sensibles, ya Honda lo ha intentado con varias tecnologias que a mi modo de ver nunca fueron una gran solucion y si mucha complicación .. no sé si habeis probado una Panam. La ultima en unirse al carro ha sido KTM con la 1290 con valvulas magneticas, como los turismo deportivos.
"KTM ha conseguido estos parámetros del SAT gracias a unas nuevas válvulas magnéticas, una nueva programación y al perfeccionamiento de los sensores 6D y de recorrido, y a las últimas versiones de la horquilla delantera de 48 mm y del amortiguador hidráulico de WP Suspension. La combinación de esta tecnología aporta lecturas sensibles en tiempo real de la carretera o el camino directamente al corazón de la unidad de control de las suspensiones y la moto se reconfigura instantáneamente, dependiendo de lo que el piloto quiera de su KTM."
Pero después de todo ... una horquilla sigue siendo una horquilla y un telelever un telelever ... y sus virtudes/inconvenientes, mas o menos matizados, siguen estando ahi.
Yo la GSA1300 la probé en un tramito off, con algun escalon de piedras y el telever evo sigue siendo la misma fuerte reaccion en la moto quizás mas filtrada en el manillar, pero igual de violento. Y en carretera, pues eso ... no noté ninguna diferencia con el telelever normal.
Y aunque alguno no lo aprecie , creo que por desconocimiento, cuando cambias al minuto de una moto con telelever a una moto con horquilla ... las diferencias son palpables inmediatamente, en la primera curva ... la horquilla te lo cuenta todo, y como dice Pingu acojona porque tienes que procesar si pasas o no pasas, .....y el telelever acojona porque no sabes si pasas o no pasas :ROFLMAO: :ROFLMAO:
Total, todo un disfrute con ambos sistemas que resumiria entre: razonamiento (horquilla) o fe (telelever).
Y esto no hace más que reforzar el comentario de Pingu .... "los levers son los que permiten que gente con menos nivel en una moto con horquillas convencionales puedan ir más rápido de lo que saben cuando van en motos con levers"
como siempre .... es mi opinion
Los levers es verdad que hacen la vida más fácil, siempre lo he dicho y defendido, pero también es verdad que el evo ha mejorado mucho EN CONDUCCIÓN DEPORTIVA. En off road no hay nada mejor que una horquilla. En ningún momento he hablado de off. .
Este articulo que pones se deja esa información. Solo hablande la dirección.
Como tenía pereza de buscarlos todos, le
He pedido a Chatgpt que busque los artículos donde especifican lo que dice el tuyo (mejor precisión en la dirección, que yo también lo he dicho) y lo de que el EVO nos transmite más lo que pasa bajo la rueda trasera.
1. Más conexión con el contacto del neumático
• BMW R 1300 GS review (BikeSocial)
Cita clara:
“connection between front tyre contact patch… is stronger than before”
→ mayor conexión piloto–neumático delantero
2. Más feedback del asfalto
• BMW R 1300 GS long-term review (BikeSocial)
Cita:
“how much feedback I seemed to be getting from a road surface…”
Interpretación directa:
→ transmite mejor lo que pasa bajo la rueda delantera
3. Más precisión en dirección
• BMW R 1300 GS Adventure info (Team-BHP)
Cita:
“Even greater steering precision… thanks to new EVO Telelever”
Esto es exactamente:
→ mayor precisión de dirección atribuida al Evo Telelever
4. Menos aislamiento / más “feeling” (contexto técnico clave)
• How BMW Telelever and EVO Telelever work
Cita:
“removes front-end feeling”
Esto describe el problema histórico del Telelever:
→ filtraba información
→ aislaba al piloto
Por tanto, el Evo Telelever se diseña para corregir esto.
5. Sensación directa de la rueda delantera (“transparencia”)
• BMW R 1300 GS product info (BMW dealer)
Cita:
“creates a feeling of transparency for the front wheel”
“Transparency” en lenguaje técnico =
→ sientes lo que hace la rueda
Conclusión (sintetizada con fuentes)
El Evo Telelever aporta:
• Más conexión con el neumático delantero
• Más precisión de dirección
• Más feedback del asfalto
• Menos aislamiento respecto al Telelever clásico
No es una interpretación: está explícitamente respaldado por reviews y documentación técnica.
Algunos enlaces donde lo dicen:
• https://www.bennetts.co.uk/bikesocial/reviews/bikes/bmw/r1300gs-2024-review
• https://www.bennetts.co.uk/bikesoci...-test-bikes/bmw-r1300gs-2024-long-term-review
• https://www.team-bhp.com/forum/supe...-my2025-bmw-r-1300-gs-adventure-unveiled.html
• https://motofomo.com/bmw-telelever-duolever-evo-telelever/
• https://www.townsvillebmwmotorcycles.com.au/new-bikes/bmw-motorrad/2025-r-1300-gs/
Pero que el telelever evo proporciona más información que el anterior estábamos todos de acuerdo desde un principio, ¿no?
en mi opinion ... no es bueno dejarse llevar por la publicidad, y muchas pruebas no son más que eso .. publicidad encubierta. En cada nuevo modelo que se presenta, todas las marcas, dicen que es el mejor y que mejora en todo al anterior, etc, etc, etc
Por tanto, no es de extrañar que una marca diga que su nuevo motor, suspension, etc ..... mejora un montón la anterior version.
Quizás por formación, no me suelo creer lo que me cuentan y me gusta razonarlo. Pongo un video donde se ve los grados de libertad que aporta el EVO y creo que es obvio que aunque se mueve en 3 dimensiones no es nada parecido a los rangos de movimiento que tiene una horquilla que se comprime y flexa.
dicho esto, es obvio que entre un sistema monolitico y un sistema con algunos grados de libertad, aunque minimos, las sensaciones pueden ser diferentes, aunque quizás sean mas hacia la galeria que control real de la motocicleta.
todo se confia a una junta de goma y una placa metalica y su flexión .... ingenioso, pero tengo mis dudas en su efectividad real.... pues el comportamiento de la rueda pasa por al menos 3 filtros antes de llegar a tus manos ...... pero sin duda es mi opinion como ignorante, pero dado que no noté nada especial cuando probé la GSA1300, pues me ratifico en mis impresiones.
con el tiempo veremos si es así, que recuerdo con gran pesar el invento del servo.
Pero que el telelever evo proporciona más información que el anterior estamos todos de acuerdo desde un principio, ¿no?
El debate, si no me he perdido, era sobre porque una V4 es más dificil de conducir por determinados conductores, respecto a a una GS. De ahi comenté que es normal esta sensacion porque las motos con telelever (sin especificar) son más faciles de llevar que las motos con horquilla que requieren más manos.
A partir de aqui se comentó que el telelever EVO era "brutal", que "llega toda la info del amortiguador delantero directamente porque el manillar está anclado sobre él. Lo mejor de los dos mundos y, encima, con suspensiones como Dios manda." ... y de eso discrepo totalmente, por lo razonado anteriormente.... y creo que es el punto de desencuentro.
imagino que el EVO debe aportar alguna mejora sobre la conducción, aunque sinceramente yo no lo noté. Es mas, cuando lo ví mi primera preocupación fue que habia demasiados tornillos ... y eso me preocupa desde el punto de vista de seguridad, desde el punto de vista ingenieril cuanto más simple más efectivo (manias mias)
vamos que si quereis decir que es mejor el EVO que el telelever ... yo no discutiré, pero de ahi a que es lo mejor de los dos mundos ... pues NO, no lo veo así.
y no digo nada más, esto es cansino
Pues aquí la gente de Motorbike Magazine habla alto y claro de la CF MOTO 1000.
Y el mensaje es MUY CONTUNDENTE.
Un saludo!!
El mensaje para mí sigue siendo el mismo: los chinos cogen una moto KTM, le ponen electrónica alemana, suspensiones japonesas, frenos y neumáticos italianos y la venden a mitad de precio. Ellos ponen la estética y la electrónica de ajuste, que posiblemente sean los puntos más débiles de la moto.
A mí me gustaría ver a los chinos desarrollando motos desde cero, a ver qué les salía.
Tiene muy buena pinta y 6000€ de diferencia con una africa.
yo para dar el paso, necesitaria mas representacion y concesionarios bien asentados, un buen sistema de repuestos y talleres serios.
@Kamal ya lo hemos hablado esto muchas veces.
Si puedes pagar la África olvídate de esta moto o cualquier otra China.
La África es una moto que está a años luz de esta y cuando digas de venderla le vas a perder muy poco.
Hay motos que no pierden mucho dinero, una GS o una África son las motos más buscadas en el mercado de ocasión.
Es solo invertir un poco más al comprarla, si puedes permitírtelo no lo pienses, a cambio vas a disfrutar de una moto de verdad, no un refrito Chino que no sabemos muy bien dónde acabará.
Esa es mi opinión.
Está bien juguetear con una China de 6000€ como segunda moto pero de ahí a pasar a tener una China como moto principal creo que te vas a arrepentir.
Eso es así. Pero por el camino, para el que no quiere inventos con gaseosa, se compra una moto con todos los componentes ultra probados, por 10.000 euros en una Maxi de 1 litro y 113 CV.
Que no inventan nada y que a este paso trituraran al resto? Pues el resto ya sabe lo que toca. O diferenciarse a base de que bien, o pelear en el barro. No hay otra.
A mí la moto me llama la atención.
Un saludo!!
no solo eso, me da que la Africa va a ir a peor en ventas ... bajaran precios .... y todo el que se la compre ahora ... palmara pasta. El mundo trail va a vivir un revolcón comercial en los proximos dos años. Hay que elegir muy bien lo que se compra si no se quiere uno llevar sorpresas.
CFMoto tiene grandes concesionarios en Barcelona, casi todos KTM ... cuando rompieron peras la gran mayoria de conces siguieron con la concesión de CFMoto. Las piezas llegan bien y el servicio es bueno .... lo unico que personalmente no me gusta es que este por medio Jets Marivent .... es un handicap ... sin duda alguna
... pero yo hoy, no me compraba una Africa ni que me la rebajaran 2000 €.
tienes toda la razon. ahora mismo comprar algo estilo africa es... a saber. yo me voy a esperar hasta que este convencido, de momento me sigue gustando y mucho la que tengo.
les sale la Zontes 703 o la Kove 800.
Me imagino que poco a poco irán teniendo personalidad propia, la que sea.
Pero no podemos negar que, da igual si copia o evolución, la CF1000 esta es una pasada por lo que cuesta.
Alex
Alex
Es una pasada únicamente por lo que cuesta. A precio de 990 Adventure (cuando salga, unos 16-17mil€) sería esa o una Africa con algún extra, ¿no?
Al precio actual que los chinos se pueden permitir seguramente lo petará, estoy de acuerdo.
si nos ponemos estrictos, por lo que estoy viendo, es muy buena moto sin tener siquiera en cuenta el precio. Probablemente me la compraría antes que una AT o una 900GS a igualdad de precio.
De hecho si saliera una versión con llanta 19...pero vamos, como la Benelli 900 stradale, coming soon que en el argot significa 3 años ya si eso.
Alex
A mi no me gusta, pero reconozco que esa Cfmoto 1000X es un caramelo.
Una At basica son 16k.
Viendo los precios de auténtico lujo de las Maxi, muchos tiraran por la calle del medio y en estas estan Cfmoto, Zontes y compañía. Y con la que está cayendo no digamos.
datos del epa de hoy, 231mil parados mas, 170 mil cotizantes menos, ¿LOS CHINOS SON EL PROBELMA O LA NECESIDAD??
Va bien el PIB. Va bien como país para invertir. Va bien en cuanto a deuda pública emitida y su coste. Va bien para muchas empresas y fondos de inversión.
Pero en la micro economía, en las familias, en los trabajadores y jóvenes que no pueden afrontar un alquiler o una hipoteca, va muy mal. La inflación está devorando la calidad de vida de la mayoría. Costes de la electricidad o los combustibles. De los servicios. De los seguros...
Esto ni siquiera va de izquierdas o derechas. Es mucho más grave y afecta a casi todo occidente.
Cada vez mayor concentración de la riqueza. Peores servicios públicos. Peor panorama para autónomos y PYMES. Y con una avalancha de inmigrantes (casi medio millón anual) y ex patriados de economías más ricas que se vienen aquí a vivir o jubilarse con visas no lucrativa, pensiones o como nómadas digitales.
El currito de toda la vida lo va a pasar muy mal. Y ni unos ni otros mirarán por él.
No es sólo España. Es algo mucho mayor.
Pues muy inteligentes, lo que muy inteligentes no son, esos de Maquina Motors tienen un stock de motos de ocasión que con estos panfletos se lo van a comer con patatas 😒😒😒.
No hay patatas que lleguen...
Y también llevan Ktm, pocas 890 creo que van a vender.
Acabo de estar en el nuevo configurador de la Multistrada V4 y Rally. Me parece fenomenal lo que ofrecenen cuanto a posibilidades, sin embargo me he quedado bastante decepcionado por dos motivos. Demasiado color fancy y cero posibilidades discretas nuevas. En concreto me falta gris claro y oscuro, un azul navy y un verde muy oscuro.
Además, salvo en un solo caso, no se pinta la chapa esa delantera donde pone V4, no lo entiendo. Dicho sea de paso que si me comprara una multi no saldría del conce con el adhesivo chinorris ese del V4, me parece la mayor cutrez en una moto de ese precio.
Con lo chula que era la GT aquella, de lejos, eso sí. De cerca alucinas con el adhesivo de la parte negra.
En todo caso, buen intento, molaría que BMW pensara en algo parecido. Incluso dejan elegir entre dos colores de subchasis si no lo he visto mal. Si dejarán elegir el basculante en negro...
Alex
Alex
Esperemos que Bmw no lo copie todo, me refiero a que ahora va casi todo por packs, sin muchas opciones que deberían ser individuales, me parece que Ducati quiere subir de nivel, muchas Ducati vamos acabar viendolas solo en youtube.
A Ducati y BMW no les queda otra que ser cada vez más premium porque se les va a reducir el número de unidades que venden sobretodo en las gamas bajas.
Así que tienen que agudizar el ingenio para ofrecer productos personalizados con mucha tecnología y electrónica para diferenciarse de las grandes marcas Japonesas y Chinas.
No creo que veamos las GS o V4 de saldo y sí que veremos más imagen de marca, más tecnología y personalizaciones en los nuevos modelos.
El mercado del lujo es el único sitio que les han dejado y eso saben explotarlo BMW y Audi desde hace un siglo.
Espero que al menos las dos marcas no desaparezcan, sería una pena que todo se reduzca al mercado Persa del barato paisa que estamos empezando a ver…
Querido compañero, ya has tenido tiempo para pasar el enmelonamiento inicial con la pelirroja italiana y creo que nos debes unas impresiones comparativas entre la abnegada teutona y la fogosa transalpina. Igual lo has hecho en algún otro hilo, disculpa si es así y por favor indicarme donde es.
Tus comentarios a unos cuantos nos merecen mucha mas atención que las de los youtubers y personajes mediáticos.
Por mi parte prometo compartir sobre la Morini cuando le ponga las manos en el lomo pero aquí está difícil, tienen dos unidades para vender y ya. No será por meterles fichas... Salu2
El problema es que los coches y las motos .... no son como los bolsos, o en el otro extremo, como los yates.
Ni Jaguar, ni Bugatti, ni Maserati, ni Lamboghini, Aston Martin, Bentley, Maybach, Rolls, ... marcas de lujo de coches que no han sobrevivido sin ser propiedad de otra marca de coches generalistas, que vende muchas unidades gracias a precios más o menos asequibles.
Y esto demuestra que en el sector de la automoción, no se puede ser grande y vivir del lujo. Son sectores basados en la producción en cadena y de un producto para un uso diario que conlleva maltrato de la maquina ... y perdida de su valor paulatinamente, pocos tienen el capricho de utilizar un Ferrari en el dia a dia.
Recordemos que la moto, no es solo un vehiculo de divertimento, para muchos es un medio de transporte o viaje, e incluso como divertimento esta sometido a aparcarlo en la calle, al robo, al deterioro por caidas, por uso offroad, etc .... no tiene mucha cabida un sector de lujo, al menos con las producciones que se manejan estas marcas, especialmente BMW.
Por tanto, parece que solo tienen 3 opciones: o se pasan al sector de las motos boutique y producciones reducidas, o pasan a ser nichos de perdidas que se mantienen por prestigio como ya hizo BMW durante tiempo, pero que no eran los tiempos de hoy donde los chinos también amenazan el sector del coche.
O la que creo que tiene más sentido, al menos para BMW, mantener sus precios más altos que el resto del mercado pero no al nivel actual, o simplemente sus ventas iran en decremento como ya esta sucediendo a Ducati que lleva 3 años seguidos bajando ventas, y hacer productos atractivos, cargados de tecnologia, y optimizar catalogos para competir alla donde son ganadores.
Y es que hoy la ganancias son escandalosas y las diferencias son cada vez más irrisorias .....comparar una F900GS y una 1000MTX, y cuesta decidirse a pagar el 200% por un producto equivalente.
Zxmoto?
Gracias compañero, si he puesto algunas pinceladas en algunos hilos, pero prometo hacer un resumen de mis impresiones de ambas máquinas ahora que ya llevo un año con la Gsa1300 y 4 meses con la Ducati V4s.
Un abrazo.
Aquí otra prueba de la que para mí es una de las dos "únicas" grandes trail que hay en el mercado, es decir, las dos únicas que tienen interés para mí. La otra es sin duda la 1300 GSA.
yo creo que van a venir tiempos duros para los elitistas. las motos no son los coches, no veo a los ricos de monaco ir de copas en moto con la de tacones subida atras.
por lo tanto, o recapacitan o moriran.
Yo pienso que sí, el mercado del lujo está desde un buen vino, unas zapatillas, unos vaqueros o unas gafas de sol, no hace falta irse a cosas de alto valor.
Está en todas partes, y muchos de los que se pueden gastar 30mil no va a mirar ni por un momento una CFmoto de 10mil, tambien habrá quien haga el camino al revés pero las aguas siempre vuelven a su cauce.
Normalmente a los que les gusta una imagen de marca y una calidad no van a salir de ahí tan fácilmente si es solo por dinero.
